Ga door naar hoofdinhoud
Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement
Wat je nodig hebt
  1. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Housing Assembly: stap 1, afbeelding 1 van 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 2, afbeelding 1 van 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: stap 3, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Reduction Gear Assembly: stap 3, afbeelding 2 van 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 4, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 4, afbeelding 2 van 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 5, afbeelding 1 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 5, afbeelding 2 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 6, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 6, afbeelding 2 van 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 7, afbeelding 1 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 7, afbeelding 2 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 7, afbeelding 3 van 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 8, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 8, afbeelding 2 van 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 9, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 9, afbeelding 2 van 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 10, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 10, afbeelding 2 van 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 11, afbeelding 1 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 11, afbeelding 2 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 11, afbeelding 3 van 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 12, afbeelding 1 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 12, afbeelding 2 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 12, afbeelding 3 van 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
  13. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: stap 13, afbeelding 1 van 2 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement, Diaphragm Assembly with Bushing: stap 13, afbeelding 2 van 2
    • Remove the metal piston from the diaphragm assembly.
  14. Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 14, afbeelding 1 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 14, afbeelding 2 van 3 Milwaukee 5262-21 Diaphragm Assembly with Bushing Replacement: stap 14, afbeelding 3 van 3
    • Using a metal spudger, pry the o-ring off of the assembly.
Conclusie
Payton Parker
534 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G3, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G3
4 Leden
6 handleidingen geschreven
Één opmerking
to reasemble .
Which is the correct position of the Shift knob assembly ?
Javier Martinez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 1,033
