Ga door naar hoofdinhoud
Milwaukee 2780-20 (2) Ball Bearings Replacement
Wat je nodig hebt
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: stap 1, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: stap 1, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: stap 1, afbeelding 3 van 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 2, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 2, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 2, afbeelding 3 van 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 3, afbeelding 1 van 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 4, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 4, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 4, afbeelding 3 van 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: stap 5, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: stap 5, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: stap 5, afbeelding 3 van 3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 6, afbeelding 1 van 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 6, afbeelding 2 van 2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 7, afbeelding 1 van 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 7, afbeelding 2 van 2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 8, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 8, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 8, afbeelding 3 van 3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 9, afbeelding 1 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 9, afbeelding 2 van 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 9, afbeelding 3 van 3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 10, afbeelding 1 van 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: stap 10, afbeelding 2 van 2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 3,071
