Ga door naar hoofdinhoud
Milton Bradley Simon Light Bulb Replacement
Wat je nodig hebt
  1. Milton Bradley Simon Light Bulb Replacement, Light Bulb: stap 1, afbeelding 1 van 2 Milton Bradley Simon Light Bulb Replacement, Light Bulb: stap 1, afbeelding 2 van 2
    • Make sure the game is powered off by switching the On/Off switch to the left.
  2. Milton Bradley Simon Light Bulb Replacement: stap 2, afbeelding 1 van 1
    • Take off the green and red switches on top of the game by pulling them off.
  3. Milton Bradley Simon Light Bulb Replacement: stap 3, afbeelding 1 van 1
    • Flip the game over.
  4. Milton Bradley Simon Light Bulb Replacement: stap 4, afbeelding 1 van 1
    • Slide the battery cover off of the back.
  5. Milton Bradley Simon Light Bulb Replacement: stap 5, afbeelding 1 van 1
    • Take out the batteries.
  6. Milton Bradley Simon Light Bulb Replacement: stap 6, afbeelding 1 van 1
    • Use the Phillips Head screwdriver to unscrew the screws located at the four corners of the game.
  7. Milton Bradley Simon Light Bulb Replacement: stap 7, afbeelding 1 van 1
    • Pull off the back plastic case of the game.
  8. Milton Bradley Simon Light Bulb Replacement: stap 8, afbeelding 1 van 1
    • Carefully place the top half of the game aside.
    • The top half is the half with the colored panels. Carefully place this half aside so the buttons do not fall out of place.
  9. Milton Bradley Simon Light Bulb Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the 4 light bulbs from the bottom half of the game.
Conclusie
Follow these steps in reverse to reassemble the device.
Simon Redondo
113 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 54
Altijd: 4,101
