Inleiding
I own an ID DEFENDER 10-sheet shredder that will go through the motions of shredding but the paper comes out wavy and not shredded. My guide will provide instructions to replace the mill cutter paper stripper and stripper guide so the shredder can shred paper correctly.
Wat je nodig hebt
Unplug the shredder from the wall electrical outlet.
Remove the shredder from its catch basket and place it face down on a flat surface.
Remove the gears from both sides.
If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
Één andere persoon heeft deze handleiding voltooid.
