Ga door naar hoofdinhoud
Midland X-tra Talk Radio LXT118 Speaker Replacement
Wat je nodig hebt
  1. Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: stap 1, afbeelding 1 van 2 Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: stap 1, afbeelding 2 van 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Speaker Replacement, Case: stap 3, afbeelding 1 van 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 8, afbeelding 1 van 1
    • The speaker is now disassembled!
  9. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: stap 9, afbeelding 1 van 1
    • Solder the new wires to the circuit board in the spots denoted by the two red circles.
  10. Midland X-tra Talk Radio LXT118 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Place the speaker back inside the shell casing in the same way that it was originally placed.
    • Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
Conclusie
James Tucker Dunn
371 Reputatie
6 handleidingen geschreven
Cal Poly, Team 19-43, Regan Winter 2013 Lid van Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 760
