Inleiding
This guide will display the step-by-step process of fixing and/or replacing a faulty antenna. Soldering may be involved, so be prepared!
Wat je nodig hebt
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
5 andere personen hebben deze handleiding voltooid.
