Midiman Oxygen 8 LCD Screen Replacement
Wat je nodig hebt
Remove the 8 mm M3 Phillips head self tapping machine screws.
Remove all 13 of the back plate screws.
Removal of Ribbon Cables
To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
The LCD screen is attached to the same circuit as the Data Slide bar on the reverse of the front face plate.
Remove the four M1.5 x 3 screws
