Inleiding
For this guide, you will be replacing the device's camera. You will need to be mindful and careful of the device's other exposed components when following this guide.
Wat je nodig hebt
Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
Near the top left of the device, gently unclip the gold ribbon cable by pulling up the black clip holding it in place and removing the ribbon.
Één andere persoon heeft deze handleiding voltooid.
