Ga door naar hoofdinhoud
Microtek ScanMaker 5900 Motor Tread Replacement
Wat je nodig hebt
  1. Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: stap 1, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: stap 1, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Remove serial port connection: stap 1, afbeelding 3 van 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: stap 2, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: stap 2, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Remove Lid: stap 2, afbeelding 3 van 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: stap 3, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: stap 3, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Detach plastic latches: stap 3, afbeelding 3 van 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: stap 4, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: stap 4, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Continue latch detachment: stap 4, afbeelding 3 van 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: stap 5, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: stap 5, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement, Fully remove the upper lid: stap 5, afbeelding 3 van 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 Motor Tread Replacement, Stepper Motor: stap 6, afbeelding 1 van 2 Microtek ScanMaker 5900 Motor Tread Replacement, Stepper Motor: stap 6, afbeelding 2 van 2
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  7. Microtek ScanMaker 5900 Motor Tread Replacement: stap 7, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement: stap 7, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement: stap 7, afbeelding 3 van 3
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  8. Microtek ScanMaker 5900 Motor Tread Replacement: stap 8, afbeelding 1 van 3 Microtek ScanMaker 5900 Motor Tread Replacement: stap 8, afbeelding 2 van 3 Microtek ScanMaker 5900 Motor Tread Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
  9. Microtek ScanMaker 5900 Motor Tread Replacement, Motor Tread: stap 9, afbeelding 1 van 2 Microtek ScanMaker 5900 Motor Tread Replacement, Motor Tread: stap 9, afbeelding 2 van 2
    • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
    • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
  10. Microtek ScanMaker 5900 Motor Tread Replacement: stap 10, afbeelding 1 van 1
    • The plastic wheel and it's mount will be loose.
    • Remove the shaft holding the plastic wheel and the mount together
    • The tread will be completely loose.
Conclusie
Steven Shaginyan
39 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-9, Regan Fall 2011 Lid van Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,452
