Ga door naar hoofdinhoud
Microsoft Zune HD Lower Rear Panel Replacement
Wat je nodig hebt
  1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: stap 1, afbeelding 1 van 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Lower Rear Panel Replacement: stap 2, afbeelding 1 van 2 Microsoft Zune HD Lower Rear Panel Replacement: stap 2, afbeelding 2 van 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: stap 3, afbeelding 1 van 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: stap 3, afbeelding 2 van 2
    • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
    • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
    • Repeat this process for the other side of the lower rear panel.
  4. Microsoft Zune HD Lower Rear Panel Replacement: stap 4, afbeelding 1 van 1
    • Carefully slide the lower rear panel away from the Zune.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 3,132
