Inleiding
These instructions show the removal of the Zune 80GB back casing. Removal of this component allows access to the internal components of the Zune 80GB.
Wat je nodig hebt
Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
Één andere persoon heeft deze handleiding voltooid.
