Ga door naar hoofdinhoud
Microsoft Zune 80 Case Replacement
Wat je nodig hebt
  1. Microsoft Zune 80 Case Replacement, Case: stap 1, afbeelding 1 van 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: stap 2, afbeelding 1 van 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: stap 3, afbeelding 1 van 2 Microsoft Zune 80 Case Replacement, Remove the Casing: stap 3, afbeelding 2 van 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
turey
400 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-5, Maness Fall 2009 Lid van Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Leden
5 handleidingen geschreven
Één opmerking
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 4,766
