Inleiding
Use this guide to replace the kickstand for your Surface RT.
Wat je nodig hebt
Turn the tablet over so the screen is facing down.
Pull up on the bottom corners to open the stand.
Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
Gently wiggle the stand until the lever in the middle is free, releasing the stand.
13 andere personen hebben deze handleiding voltooid.
12 opmerkingen
Does this replacement kickstand come with the screws also?
Where can the kickstand screws be purchased separately?
I am in the uk but there no uk options
does this fit on a window 8 pro?
Where can i get the replacement screen, for Surface RT 1516 model 64G
