Ga door naar hoofdinhoud
Microsoft Surface Pro Kickstand Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro Kickstand Replacement, Kickstand: stap 1, afbeelding 1 van 1
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws:
    • One from the left hinge
    • One from the right hinge
  2. Microsoft Surface Pro Kickstand Replacement: stap 2, afbeelding 1 van 1
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
    It is glued internally. How we reinsert the tabs back?
    anupamprasad2000 - Antwoord
Conclusie
9 andere personen hebben deze handleiding voltooid.
Mark
678 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-20, Regan Fall 2013 Lid van Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Leden
16 handleidingen geschreven
Één opmerking
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 115
Altijd: 37,962
