Ga door naar hoofdinhoud
Microsoft Surface Pro Charging Port Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro Charging Port Replacement, Display: stap 1, afbeelding 1 van 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
    Be patient. I spent at least 10 to 15 minutes warming and trying to pry up the screen with my spudgers and such. It got so hot I would use one spudger to hold the Surface from the opposite side while pried with the other spudger from the other side. I would get a little lip up and slide and when I felt resistance then I would heat more and make my way around the screen. I continued that many times until I was able to use the suction cup to pull it up.
    Dan - Antwoord
  2. Microsoft Surface Pro Charging Port Replacement: stap 2, afbeelding 1 van 2 Microsoft Surface Pro Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
  3. Microsoft Surface Pro Charging Port Replacement: stap 3, afbeelding 1 van 2 Microsoft Surface Pro Charging Port Replacement: stap 3, afbeelding 2 van 2
    • Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display, disconnect the three display cables.
    【注意!!】 画面ガラスの下部の接着がデジタイザーのフレキケーブルとも接着されています。
    両面接着剤の温めが甘かったり、無理に剥がそうとするとデジタイザーのフレキケーブルが切れますので丁寧に作業を行って下さい。
    Tacky Sato - Antwoord
    my surface pro 1 has 4 flat flexi-cables connected.
    I don’t know how to put back the narrow flexi cable. It is too thin and without a pulling tape?
    Kenneth Siu - Antwoord
  4. Microsoft Surface Pro Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Remove the display.
  5. Microsoft Surface Pro Charging Port Replacement, Charging Port: stap 5, afbeelding 1 van 2 Microsoft Surface Pro Charging Port Replacement, Charging Port: stap 5, afbeelding 2 van 2
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
    You should use T4 and T3 torx instead of T5
    Laurent akn - Antwoord
  6. Microsoft Surface Pro Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool or fingers to pry out the front camera.
  7. Microsoft Surface Pro Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Lift the outside panel from the Surface Pro
  8. Microsoft Surface Pro Charging Port Replacement: stap 8, afbeelding 1 van 2 Microsoft Surface Pro Charging Port Replacement: stap 8, afbeelding 2 van 2
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
  9. Microsoft Surface Pro Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Pull out left and right metal panels with hands
  10. Microsoft Surface Pro Charging Port Replacement: stap 10, afbeelding 1 van 1
    • Pull out the orange charging port strip using tweezers
  11. Microsoft Surface Pro Charging Port Replacement: stap 11, afbeelding 1 van 1
    • Unscrew the two T5 torx screws located on each side of the charging port.
  12. Microsoft Surface Pro Charging Port Replacement: stap 12, afbeelding 1 van 1
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jonathan Choi
1.005 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-20, Regan Fall 2013 Lid van Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Leden
16 handleidingen geschreven
4 opmerkingen
Where do you get a replacement charging port at?
Evil Robot - Antwoord
Agree where can you get the port?
J-M. M. - Antwoord
Same instructions for changing the port on a surface pro 2?
Robert - Antwoord
I followed the guide for Surface 5, inside it's very different, but the guide gave me confidence that's its possible. And In the end success. I've found for socket just on aliexpress.
Виктор X - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 177
Altijd: 28,284
