Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace the battery pack in the Microsoft Surface Pro.
Wat je nodig hebt
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
35 andere personen hebben deze handleiding voltooid.
24 opmerkingen
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
I am also trying to find out where to acquire the Surface Pro batteries...???
im also looking for a surface pro replacement battery.
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt -
