Inleiding
This guide will go over how to replace the cameras on the Microsoft Surface Pro 5, also known as the Microsoft Surface Pro (2017). The Microsoft Surface Pro 5 has two cameras: one front facing and one rear facing. Both are located underneath the black tie bar. The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
Wat je nodig hebt
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Only the screen remains.
Note, on the flex connectors of the new screen are blue strips of protective plastic covering factory applied conductive adhesive. These must be removed and the adhesive must bond to the display board in order for the touch screen digitizer to function reliably.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Black spudger worked best to get the emu shields out without damaging them.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Just like to add, on my i7, there is a fan in the top left corner and the heat sink is glued to the cover. The cover must be removed using a ph0 x 3 and one T3 (I think that is the sizes)
As the other person commented, mine also had a fan connected to the heatsink. This is present in the version with an Intel Core i7-7660U. It requires removing a T3 and T5 screw and the fan connector. Below is a link to an image showing this step.
While I do not have the fan present in my i5 version, the copper heat pipe does extend further down on the far left side (as oriented in the picture). There is an additional T3 screw on this arm as well as a small dab of adhesive on the very end.
Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
In step 19, there is a loose, clear plastic piece next to the front camera. In my disassembly, that piece managed to get lost. Can anyone tell me what the name of that part is, and where I can get one?
