Ga door naar hoofdinhoud
Microsoft Surface Pro 4 Display Replacement
Wat je nodig hebt
  1. Microsoft Surface Pro 4 Display Replacement, Display: stap 1, afbeelding 1 van 1
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • Make sure the device is turned off before you start working on it.
    • If your display is cracked, cover it with strips of packing tape to contain any glass shards and prevent injury.
  2. Microsoft Surface Pro 4 Display Replacement: stap 2, afbeelding 1 van 1
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes—but don't overheat it, or you may damage the display.
  3. Microsoft Surface Pro 4 Display Replacement: stap 3, afbeelding 1 van 3 Microsoft Surface Pro 4 Display Replacement: stap 3, afbeelding 2 van 3 Microsoft Surface Pro 4 Display Replacement: stap 3, afbeelding 3 van 3
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Insert an opening pick into the gap.
    • There are tabs on the upper right side and upper left side where it is easier to get a tool under the display.
    • Slide an opening pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • The tape is much thinner on the bottom edge than the other three sides. Do not push the tool in too far or you will damage the screen permanently.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • Separate the top edge last. There are antennas on both sides, so be careful not to damage them. If needed, you can use a bit of isopropyl alcohol to help weaken the adhesive.
  4. Microsoft Surface Pro 4 Display Replacement: stap 4, afbeelding 1 van 2 Microsoft Surface Pro 4 Display Replacement: stap 4, afbeelding 2 van 2
    • Attach a suction cup to the front of the display.
    • Using the suction cup, pull the display and base apart. You may need to hold the base in position with your hands.
    • It is usually better to place the suction cup on the left or right side of the screen, rather than in the center. This provides more leverage when removing the screen.
  5. Microsoft Surface Pro 4 Display Replacement: stap 5, afbeelding 1 van 2 Microsoft Surface Pro 4 Display Replacement: stap 5, afbeelding 2 van 2
    • There are two display cables connecting the body to the display.
    • Disconnect the cable on the right by putting a plastic opening tool under the edge of the connector and prying it up.
  6. Microsoft Surface Pro 4 Display Replacement: stap 6, afbeelding 1 van 3 Microsoft Surface Pro 4 Display Replacement: stap 6, afbeelding 2 van 3 Microsoft Surface Pro 4 Display Replacement: stap 6, afbeelding 3 van 3
    • The connection for the strip on the left is covered by a lightweight metal casing. Pry around the edges of this case with a plastic spudger. Once it is loose, pull it off.
    • Unplug the connection with a plastic opening tool.
  7. Microsoft Surface Pro 4 Display Replacement: stap 7, afbeelding 1 van 3 Microsoft Surface Pro 4 Display Replacement: stap 7, afbeelding 2 van 3 Microsoft Surface Pro 4 Display Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    Koop
    • The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device.
    • Before installing a new display, check it carefully to see if any parts need to be transferred over from the back of the old display to the new display. In particular, you may need to transfer over the NTrig board in the corner by disconnecting the two attached ribbon cables and using heat and gentle prying to carefully separate the glue securing the board.
    • To replace the adhesive securing the display, carefully remove any old adhesive from both the device and the back of the display. Clean and prep the surface with isopropyl alcohol and a lint-free cloth, swiping the cloth in one direction (not back and forth). Apply a strong double-sided tape, such as 2 mm Tesa 61395.
Conclusie
106 andere personen hebben deze handleiding voltooid.
Andrew Prater
5.728 Reputatie
4 handleidingen geschreven
Metro State, Team 1-3, Carpenter Spring 2016 Lid van Metro State, Team 1-3, Carpenter Spring 2016
MSU-CARPENTER-S16S1G3
2 Leden
12 handleidingen geschreven
60 opmerkingen
Thank you for your guide.
I've removed the cracked screen from my Surface Pro 4 and hope to replace it with a new screen I bought on eBay. Unfortunately, the new screen doesn't seem to have the NTrig board attached to it.
Is it possible to remove that little board from the old screen? If so, how?
alex - Antwoord
I'm also interested on this. as I can't find a screen seller that includes the NTrig board. Did you manage to do it, Alex?
Óscar Espeso Gil -
Yes you can heat up the board and remove it and move it over to the new screen. However my problem is that now I have a vertical dead spot about 2 inches wide from the "J" key to the "L" key up and down the screen. I can't find any damage to the cables or boards... I have replaced the screen twice now and nothing.
Jordan Mershon -
Same problem as the guy above, moved the n-trig board over, touch is unresponsive in certain spots, anyone find a solution to this?
Raul Garcia -
I'll be moving the board over as well, I am told to make sure the cables are completely connected, Check and Re-Check. This seemed to have fixed most problems with the touch being unresponsive in some area's.
jayroca23 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 45
Afgelopen 7 dagen: 358
Afgelopen 30 dagen: 1,519
Altijd: 227,932
