Deze vertaling geeft mogelijk niet de meest recente updates van de bronhandleiding weer. Help ons met het updaten van de vertaling of bekijk de bronhandleiding.
Inleiding
指导将会告诉你如何安全的移除你的Microsoft Surface Pro 3电池。先移除你的触控板和显示器在跟随指导移除你的电池
Wat je nodig hebt
要移除显示屏,首先要加热软化粘合剂。可以使用热垫、热风枪或 iOpener。如沒有以上工具,也可以使用吹风机。
稳步均匀地加热显示屏四周,直到热到无法触摸为止,并尽量将温度维持几分钟。
反向跟随这些说明安装你的设备
反向跟随这些说明安装你的设备
52 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
83%
CoikVollin helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
32 opmerkingen
Do you have to glue everything back together? Do you heat the parts back up to get the glue to stick again?
I slowly removed the old adhesive watching out for glass shards. A spundger and razer blade didn’t really help. In the end, I just used my fingernail and finger to roll the adhesive like I was removing rubber cement. It too about 30 minutes but I was able to get it cleaned off. I replaced the adhesive with 2 mm Tesa tape. This worked great.
Has anyone ever successfully opened a surface pro 3 without breaking the screen?
Yes I have successfully open the surface pro with out breaking the screen by using a heat gun, the islack and the using the picks around the screen as anchors, then use the islack as you will use it to replace the screen in the iphone. It takes time and patience and a lot of heat. It took me 25 minutes to remove the screen with out breaking it.
Only wizards can accomplish this task without breaking the screen. Yes the screen must be reheated for the glue to stick again. A simple fix to avoid all of these problems is to switch to Apple products.
