Inleiding
你要知道一些潜在的信息。
-这次更换绝对是一个挑战,除非你有非常自信的DIY动手能力。你最好还是交给一个更专业的维修机构。例如:微软。
-注意查找正确的说明版本,小心更换你的屏幕。大多数设备的卡扣使用V1.1版本。如果你更换的屏幕不是当前版本的卡扣。或者卡扣的版本错误。那就麻烦大了。
-最重要的是,金属部件是不能弯曲的。如果你忽视了金属部件并且不小心弯曲了它。金属部件会使你的新屏幕安装出现缝隙甚至不能贴和,专业并小心地处理你的金属部件。
Wat je nodig hebt
要移除显示屏,首先要加热软化粘合剂。可以使用热垫、热风枪或 iOpener。如沒有以上工具,也可以使用吹风机。
稳步均匀地加热显示屏四周,直到热到无法触摸为止,并尽量将温度维持几分钟。
随着这些指导重新安装你的设备,经过了一次的重装之后,还要更新设备固件、驱动。甚至还要将你的设备恢复出厂设置。
146 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
52 opmerkingen
Hi,
I live in the UAE and I have a broken screen. The screens work just no touch screen. Getting it replaced over here will cost a lot. Over 600 usd. The screen will cost the most.
Instead, I thought about buying the screen and digitizer myself and have someone fix it here for me. This will he relatively cheaper.
How do I know which screen and digitizer to buy? And where can I buy one from? I found the v1.1 on etrade supply but I don't know how reliable this site is.
Can you please guide me?
Thanks
JuliusCes
what do you ended up doing? same problem here and i dont want to crack it open just to check the screen model
lautaro -
i’ve just changed my screen with mixed results. I tried to remove the cracked screen in case it turned out to be something other than v1.1. in fact I ended up chipping off hundreds of shards around the edges until it finally came out. It was a 1.1, hooray! So then I plugged in the replacement and it works great, but I’m afraid to tape it in permanently because I damaged all three antennae which I didn’t anticipate being buried in the adhesive along the top edge. As I was chipping glass and peeling pieces out I didn’t realize those were prices of the antennae I was tearing out. Wi-Fi speed test runs fine in my shop where I’m close to the access point. I‘m trying to decide whether to order the antennae to replace just in case. I’l need those tiny torx drivers to remove screws.
Contrary to the photos above I didn’t need to remove screws to remove the display. The connector is actually the one just below the one indicated -the smaller one that has no screw.
Happy fixing!
Look up the correct replacement screen by including your Surface model # in the query. Find your model # under the kickstand.
Model # location image:
Many thanks for the reply. I ended up getting the screen fixed via Microsoft. It turns out that they have a service center in the UAE. Something that not even the UAE microsoft store was aware of!
Cheers,
Julius
