Ga door naar hoofdinhoud
Microsoft Surface RT Kick-stand Replacement
Wat je nodig hebt
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: stap 1, afbeelding 1 van 2 Microsoft Surface RT Kick-stand Replacement, Kick-stand: stap 1, afbeelding 2 van 2
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Kevin Hua
1.615 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-23, Forte Winter 2013 Lid van Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Leden
17 handleidingen geschreven
12 opmerkingen
Where do you get the replacement kickstand from?
Ray - Antwoord
is this compatible with surface pro 1 ?
arqueiro - Antwoord
Do you offer a replacement kickstand for the surface rt 2?
allie - Antwoord
Does this replacement kickstand come with the screws also?
Andrea Thompson - Antwoord
Where can the kickstand screws be purchased separately?
Anthony Welch - Antwoord
I am in the uk but there no uk options
we love eletronics - Antwoord
Does this work for a broken hinge?
schmee - Antwoord
i need to find the torx #5 screws to mount the kickstand. any suggestions?
Harry - Antwoord
does this fit on a window 8 pro?
JOHN FAVIS - Antwoord
Where can I get the replacement screws from?for surface rt kickstand?
Wishram - Antwoord
Where can i get the replacement screen, for Surface RT 1516 model 64G
mzizijames - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 40,582
