Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the kickstand for your Surface.
  1. Turn the tablet over so the screen is facing down. Pull up on the bottom corners to open the stand.
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
  2. PC Laptop batterijen
    Een snelle fix voor een grote boost.
    Nu winkelen
    Nu winkelen
Conclusie
13 andere personen hebben deze handleiding voltooid.
Kevin Hua
1.268 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-23, Forte Winter 2013 Lid van Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Leden
12 handleidingen geschreven
Where do you get the replacement kickstand from?
Ray - Antwoord
is this compatible with surface pro 1 ?
arqueiro - Antwoord
Do you offer a replacement kickstand for the surface rt 2?
allie - Antwoord
Does this replacement kickstand come with the screws also?
Andrea Thompson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 15
Afgelopen 7 Dagen: 79
Afgelopen 30 Dagen: 217
Altijd: 34,768
