Ga door naar hoofdinhoud
Microsoft Surface Book Keyboard Heat Sink Replacement
Wat je nodig hebt
  1. Microsoft Surface Book Keyboard Heat Sink Replacement, Remove the display with the Detach button: stap 1, afbeelding 1 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Remove the display with the Detach button: stap 1, afbeelding 2 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Remove the display with the Detach button: stap 1, afbeelding 3 van 3
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. Microsoft Surface Book Keyboard Heat Sink Replacement, Manually detach the display: stap 2, afbeelding 1 van 2 Microsoft Surface Book Keyboard Heat Sink Replacement, Manually detach the display: stap 2, afbeelding 2 van 2
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. Microsoft Surface Book Keyboard Heat Sink Replacement, Bend a paper clip: stap 3, afbeelding 1 van 2 Microsoft Surface Book Keyboard Heat Sink Replacement, Bend a paper clip: stap 3, afbeelding 2 van 2
    • Straighten out one section of a paper clip.
  4. Microsoft Surface Book Keyboard Heat Sink Replacement, Push the paper clip into the hole: stap 4, afbeelding 1 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Push the paper clip into the hole: stap 4, afbeelding 2 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Push the paper clip into the hole: stap 4, afbeelding 3 van 3
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. Microsoft Surface Book Keyboard Heat Sink Replacement, Release the mechanism: stap 5, afbeelding 1 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Release the mechanism: stap 5, afbeelding 2 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Release the mechanism: stap 5, afbeelding 3 van 3
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. Microsoft Surface Book Keyboard Heat Sink Replacement, Detach the second side: stap 6, afbeelding 1 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Detach the second side: stap 6, afbeelding 2 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement, Detach the second side: stap 6, afbeelding 3 van 3
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. Microsoft Surface Book Keyboard Heat Sink Replacement, Remove the display: stap 7, afbeelding 1 van 1
    • Completely power down your Surface Book before opening it up for any repairs.
  8. Microsoft Surface Book Keyboard Heat Sink Replacement, Back Panel: stap 8, afbeelding 1 van 1
    • Flip the keyboard over so you can see the back panel.
  9. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 9, afbeelding 1 van 2 Microsoft Surface Book Keyboard Heat Sink Replacement: stap 9, afbeelding 2 van 2
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
  10. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
  11. Microsoft Surface Book Keyboard Heat Sink Replacement, SD Card Reader: stap 11, afbeelding 1 van 1
    • Orient your keyboard with the internals facing up and the USB ports on the right.
  12. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 12, afbeelding 1 van 1
    • Use the T3 screwdriver to remove the two 4 mm screws on the right side of the SD Card Reader.
  13. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 13, afbeelding 1 van 2 Microsoft Surface Book Keyboard Heat Sink Replacement: stap 13, afbeelding 2 van 2
    • Remove the black ribbon cable tab on the SD card reader from the chip with a plastic opening tool. Place the tool underneath the tab and pry it off.
    • Removing this tab can be a little difficult. Be sure that you have a good angle and do not get discouraged if removing the tab takes you multiple tries.
    • Lift the SD card reader away from the keyboard to replace it.
  14. Microsoft Surface Book Keyboard Heat Sink Replacement, GPU Board: stap 14, afbeelding 1 van 1
    • Remove the larger, black ribbon cable located on the USB card with a plastic opening tool by lifting the tab away from its connector. Again, place the tool underneath the tab and pry it off.
    • This may require some force. Do not get discouraged if it does not detach on the first try.
  15. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 15, afbeelding 1 van 2 Microsoft Surface Book Keyboard Heat Sink Replacement: stap 15, afbeelding 2 van 2
    • Use the T3 screwdriver to remove three 4 mm screws located on the black bar towards the bottom of the board.
    • Use the T3 Torx Screwdriver to remove the remaining six 4 mm screws.
  16. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 16, afbeelding 1 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement: stap 16, afbeelding 2 van 3 Microsoft Surface Book Keyboard Heat Sink Replacement: stap 16, afbeelding 3 van 3
    • Lift both clamps with the blue plastic opening tool. Place the tool underneath the clamps and pry them open.
    • Use the plastic opening tool to slide ribbon cable toward the wall of the keyboard until the ribbon cables come loose.
  17. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 17, afbeelding 1 van 1
    • Wiggle the the GPU board out away from the keyboard.
    • This may require some force to remove.
  18. Microsoft Surface Book Keyboard Heat Sink Replacement, Heat Sink: stap 18, afbeelding 1 van 1
    • Unscrew the screw on the side of the black fan vent.
  19. Microsoft Surface Book Keyboard Heat Sink Replacement: stap 19, afbeelding 1 van 1
    • Remove the heat sink. It's the long, flat, black piece that runs against the bottom of the keyboard, from the graphics card to the fan vent.
    • Reapply thermal paste before reinstalling the heat sink.
Conclusie
Natalie Weisenburger
587 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-3, Livingston Fall 2016 Lid van Cal Poly, Team 20-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 46
Altijd: 3,087
