Ga door naar hoofdinhoud
Microsoft Surface 3 Speaker Replacement
Wat je nodig hebt
  1. Microsoft Surface 3 Speaker Replacement, Casing: stap 1, afbeelding 1 van 2 Microsoft Surface 3 Speaker Replacement, Casing: stap 1, afbeelding 2 van 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Microsoft Surface 3 Speaker Replacement: stap 2, afbeelding 1 van 2 Microsoft Surface 3 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Microsoft Surface 3 Speaker Replacement: stap 3, afbeelding 1 van 2 Microsoft Surface 3 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Microsoft Surface 3 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
  5. Microsoft Surface 3 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 1
    • You will be working in these areas of the Surface 3 in order to replace the speakers.
  6. Microsoft Surface 3 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use a pick to get under the speaker part and undo the adhesive that keeps it attached to the back casing.
  7. Microsoft Surface 3 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Use the pick to gently lift on the red and black wire in order to dislodge the connection between the speaker wire and the motherboard.
  8. Microsoft Surface 3 Speaker Replacement: stap 8, afbeelding 1 van 2 Microsoft Surface 3 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Repeat the same steps for the second speaker.
  9. Microsoft Surface 3 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Simply replace the old speakers by snapping the new speakers into place and connecting the red and black wire to the motherboard.
Conclusie
Andy Stone
284 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-12, Maness Fall 2015 Lid van Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 3,394
