Ga door naar hoofdinhoud
Microsoft Natural Multimedia Keyboard disassembly and cleaning
Wat je nodig hebt
  1. Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 1, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 1, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 1, afbeelding 3 van 3
    • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  2. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 2, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 2, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 2, afbeelding 3 van 3
    • Use the flat end of a spudger to pop the keys off the keyboard.
  3. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 3, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 3, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 3, afbeelding 3 van 3
    • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
    • Continue removing keys.
  4. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 4, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 4, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 4, afbeelding 3 van 3
    • Remove the 10 screws from the bottom of the keyboard.
    • Remove the upper button assembly.
  5. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 5, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 5, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 5, afbeelding 3 van 3
    • Use the tip of a spudger to push the upper button assembly buttons out from the back.
  6. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 6, afbeelding 1 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 6, afbeelding 2 van 3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 6, afbeelding 3 van 3
    • Remove the flexible keypad from the key caddy assembly.
    • The key caddies can be washed in the sink.
  7. Microsoft Natural Multimedia Keyboard disassembly and cleaning: stap 7, afbeelding 1 van 1
    • The keys can also be washed.
    • Remove the metal retaining clips before washing to prevent rust.
Conclusie
10 andere personen hebben deze handleiding voltooid.
asvnix
292 Reputatie
1 Handleiding geschreven
3Gids Commentaar
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - Antwoord
I’ve had this keyboard since it was released and it just recently started having key sticking issues, so I opted to follow this guide and was pleasantly surprised at how well it worked. Thank you for this and I hope to get another 15 years out of it.
Suggestions:
1) Instead of manually cleaning, put the keys into a clear mesh bag and into the dish washer or washing machine.
2) Spray metal retainer bars with WD-40 and wipe off to help further prevent rust.
3) Let the keys and caddies sun dry for the day to ensure they do not retain any water after cleaning.
Thomas K - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 39
Altijd: 13,993
