Ga door naar hoofdinhoud
Microsoft Lumia 640 LTE Headphone Jack Replacement
Wat je nodig hebt
  1. Microsoft Lumia 640 LTE Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 2 Microsoft Lumia 640 LTE Headphone Jack Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use your thumb or fingernail on the edge/corner of the phone to pry the back cover off the phone.
  2. Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: stap 2, afbeelding 1 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: stap 2, afbeelding 2 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement, Screen: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to pull back the sticker, revealing the screw underneath.
    • Be careful when removing the screws as they can strip easily.
  3. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 3, afbeelding 1 van 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • Use a T4 Torx driver to remove the screws in the four corners, along with the two in the middle left side (six total).
  4. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Using the T4 Torx driver, unscrew the two screws.
    • Keep these screws separate from the screws from back of the phone to ensure that the right screws go where they belong.
  5. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 5, afbeelding 1 van 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to separate the screen from the back plastic casing
    • Use tweezers to release the clip on the side of device, and remove the back of the phone.
  6. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 6, afbeelding 1 van 2 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 6, afbeelding 2 van 2
    • Using the tweezers or a spudger, pull the gold tab up gently.
    • Using tweezers or a spudger, lift the white connector up gently to completely detach the screen from the phone.
    • For motherboard replacement, skip to Step 11 after finishing this step.
  7. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 7, afbeelding 1 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 7, afbeelding 2 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 7, afbeelding 3 van 3
    • Using a plastic opening tool to carefully get under the gold strip.
    • Use tweezers to pull up the camera.
    • Use tweezers to pull up on the depth sensor.
    • This is held in by a strong adhesive.
  8. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Use a plastic opening tool to pry up the ear speaker.
    • This is held in by strong adhesive.
  9. Microsoft Lumia 640 LTE Headphone Jack Replacement, Headphone Jack: stap 9, afbeelding 1 van 1
    • Unscrew the 2 remaining screws with the T-4 bit.
  10. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    Koop
    • Use the tweezers to remove the speaker.
  11. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 11, afbeelding 1 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 11, afbeelding 2 van 3 Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 11, afbeelding 3 van 3
    • Use the plastic opening tool to lift up the black tab.
    • Use the tweezers to gently pull up on the gold tab.
    • Using the spudger, slowly get underneath the gold sticker and pry it up. This sticker is held down with a strong adhesive.
  12. Microsoft Lumia 640 LTE Headphone Jack Replacement: stap 12, afbeelding 1 van 1
    • Use the tweezers to remove the orange insulator foam.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 416
