Inleiding
Lumia 435 RM1068, RM-1069, RM1070, RM-1071
Lumia 532 RM-1032, RM1034
How to disassemble Lumia 435, Lumia 532 and replace the broken touch screen glass.
Wat je nodig hebt
Video overzicht
Switch off the phone.
Remove the battery and any inserted SIM and memory cards.
Use a screwdriver Torx T6 and remove the 4x black screws.
Unhook:
the touch screen flex cable
the LCD Display flex cable
Use a plastic tool lift up and remove the Logic board.
The Display metal shield is locked to the frame by 4x locking clips.
Use a tool with a sharp tip and careful unlock them and remove the shield.
Put some transparent scotch tape to prevent the glass from shattering.
Warm the glass for a minute to make adhesive soften.
Start the separation from the middle of the frame, where the contact area is smaller.
5 andere personen hebben deze handleiding voltooid.
Één opmerking
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
