Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
Remove the top portion of the case from the rest of the body.
Detach the side portions of the case from the body.
Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
Remove the bottom portion of the case by sliding it out from under the body.
Remove the four 7mm T10 Torx screws (two on each side of the metal body).
Remove the front portion of the case containing the lens coverings for the cameras.
The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
Disconnect the bridge connecting the first and second layer of the motherboard.
Pull the first layer of the motherboard off.
Unscrew the three 16.5mm screws using the 5mm Nut Driver.
Unscrew the one 6.5mm T10 Torx screw.
Remove the three ribbon cables.
Disconnect the left most camera from the motherboard.
