Ga door naar hoofdinhoud
Microsoft Band Wrist Clasp Replacement
Wat je nodig hebt
  1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: stap 1, afbeelding 1 van 1
    • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
  2. Microsoft Band Wrist Clasp Replacement: stap 2, afbeelding 1 van 1
    • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
  3. Microsoft Band Wrist Clasp Replacement: stap 3, afbeelding 1 van 1
    • Pull the two securing pins out of the rubberized part of the band.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chad Steese
256 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-34, Amido Winter 2015 Lid van Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Leden
6 handleidingen geschreven
3 opmerkingen
where can I purchase the replacement part
jeepgirlutah - Antwoord
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - Antwoord
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 5,147
