Ga door naar hoofdinhoud
Microsoft Band Battery Replacement
Wat je nodig hebt
  1. Microsoft Band Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
  2. Microsoft Band Battery Replacement: stap 2, afbeelding 1 van 1
    • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
  3. Microsoft Band Battery Replacement: stap 3, afbeelding 1 van 1
    • Gently pry up one edge of the battery with the plastic spudger.
  4. Microsoft Band Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove battery from its compartment with your fingers.
Conclusie
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
4 andere personen hebben deze handleiding voltooid.
Monique Salinger
390 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-34, Amido Winter 2015 Lid van Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Leden
6 handleidingen geschreven
5 opmerkingen
where can i buy the battery?
chirac - Antwoord
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon -
Will this be dangerous?
Rei zzstu Shiozawa - Antwoord
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Antwoord
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 11,971
