Ga door naar hoofdinhoud
Microsoft Band 2 Battery Replacement
Wat je nodig hebt
  1. Microsoft Band 2 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: stap 4, afbeelding 1 van 2 Microsoft Band 2 Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: stap 5, afbeelding 1 van 2 Microsoft Band 2 Battery Replacement: stap 5, afbeelding 2 van 2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: stap 6, afbeelding 1 van 2 Microsoft Band 2 Battery Replacement: stap 6, afbeelding 2 van 2
    • Pry out the battery using the plastic opening tool.
Conclusie
20 andere personen hebben deze handleiding voltooid.
Chris Syracuse
639 Reputatie
3 handleidingen geschreven
USF Tampa, Team S1-G5, Leahy Spring 2017 Lid van USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 Leden
5 handleidingen geschreven
14 opmerkingen
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Antwoord
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Antwoord
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Antwoord
The only place i found was ebay:
ftlay - Antwoord
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 12,899
