Inleiding
Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
Wat je nodig hebt
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
Once the ribbon cable is disengaged gently pull the cable off the motherboard.
3 opmerkingen
Was wondering if you could help me identify a microchip on the board by the speaker?
mine acts like it does not recognize the rca cords. help
