Ga door naar hoofdinhoud
Merch Source Projector Entertainment II Light Bulb Replacement
Wat je nodig hebt
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: stap 1, afbeelding 2 van 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: stap 2, afbeelding 1 van 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: stap 3, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement: stap 3, afbeelding 2 van 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 1 van 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 2 van 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 3 van 3
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: stap 5, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: stap 5, afbeelding 2 van 2
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
    What light bulb do I need?
    ingadewitt606 - Antwoord
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephanie
276 Reputatie
3 handleidingen geschreven
Cal Poly, Team 18-3, Maness Winter 2015 Lid van Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Leden
4 handleidingen geschreven
Één opmerking
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,822
