Ga door naar hoofdinhoud
Merch Source Projector Entertainment II Light Bulb Replacement
Wat je nodig hebt
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: stap 1, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: stap 1, afbeelding 2 van 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Vraag FixBot
      Voeg opmerking toe
    2. Merch Source Projector Entertainment II Light Bulb Replacement: stap 2, afbeelding 1 van 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Vraag FixBot
      Voeg opmerking toe
    3. Merch Source Projector Entertainment II Light Bulb Replacement: stap 3, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement: stap 3, afbeelding 2 van 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Vraag FixBot
      Voeg opmerking toe
    1. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 1 van 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 2 van 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: stap 4, afbeelding 3 van 3
      • Remove the light bulb from its housing unit.
      • Do not damage the 2 white cables leading into the light bulb panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: stap 5, afbeelding 1 van 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: stap 5, afbeelding 2 van 2
      • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
      • The light blub is held into the socket with prongs, and should easily pull straight out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephanie
282 Reputatie
3 handleidingen geschreven
Cal Poly, Team 18-3, Maness Winter 2015 Lid van Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Leden
12 handleidingen geschreven
1Gids Commentaar
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 40
Altijd: 2,662
