Inleiding
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
Wat je nodig hebt
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Één andere persoon heeft deze handleiding voltooid.
