Ga door naar hoofdinhoud
Mercedes W123 fuel sending unit disassembly and cleaning
Wat je nodig hebt
  1. Mercedes W123 fuel sending unit disassembly and cleaning, Mercedes W123 fuel sending unit disassembly and cleaning: stap 1, afbeelding 1 van 1
    • With the fuel sending unit removed (if you need help with this see the fuel sending unit replacement guide) you can proceed to disassemble and clean it.
    • Start by wiping any fuel, grime and grit from the sending unit body to make it easier for you to work with.
  2. Mercedes W123 fuel sending unit disassembly and cleaning: stap 2, afbeelding 1 van 3 Mercedes W123 fuel sending unit disassembly and cleaning: stap 2, afbeelding 2 van 3 Mercedes W123 fuel sending unit disassembly and cleaning: stap 2, afbeelding 3 van 3
    • Turn the fuel sending unit over. Handle it over a container like a bucket at all times as small amounts of diesel fuel may continue to dribble out as you turn it over.
    • On the bottom side of the fuel sending unit there is a small nut. This nut needs to be removed with a spanner bit as shown.
    • Turn it until it is removed from the base of the sending unit.
  3. Mercedes W123 fuel sending unit disassembly and cleaning: stap 3, afbeelding 1 van 2 Mercedes W123 fuel sending unit disassembly and cleaning: stap 3, afbeelding 2 van 2
    • Turn the unit back over and lift the top out of the tube that makes up the body of the unit.
    • There are two small plates (one plastic and one metal) behind the nut you removed. Mind the order of these. The metal plate is on the outside and the plastic is on the inside. Also note the orientation of the plastic plate. There is an inside face, and outside face.
    • Inside you will find the float and the three wires that make the sending unit work. You can see the three wires pictured here.
    • Inspect these wires carefully. If any of them is broken they will need to be repaired by soldering them back on to their contact points.
    • If these wires are intact, proceed to clean the internal components (wires, float, etc) and the inside of the tube with brake cleaner.
    • Be very careful when handling the insides of the sending unit as the three wires are very fragile!
  4. Mercedes W123 fuel sending unit disassembly and cleaning: stap 4, afbeelding 1 van 1
    • Wait until the components are dry of brake cleaner, then re-assemble it.
    • Consider replacing the seal at the top of the unit, just above the threaded portion. A good seal is needed to prevent diesel aromas from permeating the trunk and/or cabin.
    • When done re-install the sending unit.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.040 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
6 opmerkingen
awesome thank you, worked out fine and easy.
eviestar50 - Antwoord
2.6 spanner is NOT correct. You will need a # 10 spanner bit to do the job. Otherwise, all other info is correct, and very helpful!
nourishlight3 - Antwoord
For the tiny nut on the bottom I simply *gently* use some small Water Pump Pliers....
-Nate
vwnate1 - Antwoord
I have a Mercedes 409d I removed the sender unit and cleaned it,but broke the wires,is there definitely 3 wires to get soldered
Regards Kieron
kieron walsh - Antwoord
Hi Kieron, I cannot say with certainty that this part is the same in the 409D. As you can see, this guide was done on, and written for, the W123 diesel. However, I can say with certainty that there are 3 wires on the W123 sending unit as pictured.
Nicolas Siemsen -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 13,336
