Ga door naar hoofdinhoud
Mercedes W123 Wheel Removal Technique
Wat je nodig hebt
  1. Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: stap 1, afbeelding 1 van 3 Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: stap 1, afbeelding 2 van 3 Mercedes W123 Wheel Removal Technique, Mercedes W123 Wheel Removal Technique: stap 1, afbeelding 3 van 3
    • Start with your vehicle's wheels flat on level ground.
    • Grab your trusty lug wrench.
    • Place it on one of your lug bolts. Note I say bolt, not lug nut. This will be explained later.
    • Yank on the lug wrench, it may take a lot of force to break the lug bolt loose!
    • If you need some extra force use your leg, or even stand on the lug wrench being careful to keep your balance. This should break it free.
  2. Mercedes W123 Wheel Removal Technique: stap 2, afbeelding 1 van 1
    • Repeat the previous step on all five lug bolts, on each of the wheels you plan to remove. This loosens them, but do not remove them yet.
    • Now, you'll jack up whichever end(s) of the vehicle you plan to work on.
    • If you need guidance on this see the jacking technique guide.
  3. Mercedes W123 Wheel Removal Technique: stap 3, afbeelding 1 van 2 Mercedes W123 Wheel Removal Technique: stap 3, afbeelding 2 van 2
    • Continue to loosen each lug bolt until they can be removed.
    • You can see here the lug bolt. This will be different than the lug nuts you may be used to on other vehicles.
  4. Mercedes W123 Wheel Removal Technique: stap 4, afbeelding 1 van 1
    • You can now remove the wheel. Shown here is the rear wheel removed, exposing the brake disc.
    • Notice the lip of the hub exposed here. This will allow you to rest the wheel on the hub so you do not have to hold up its weight while getting the lug bolts back in during re-install.
  5. Mercedes W123 Wheel Removal Technique: stap 5, afbeelding 1 van 1
    • Re-install is basically the opposite of removal. However, as you tighten up the lug nuts, there are a few tips:
    • Tighten them in a "star" patter, rather than in a circular pattern. This ensure more even tightening.
    • Lower the car once they are snug so the tires are on the ground.
    • Finish tightening them with a torque wrench to ensure they are on tight enough. Your owner's manual should specify the tightness required.
Conclusie
Take a test drive. Then re-check the torque on all the lugs you removed.
3 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.284 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.525 handleidingen geschreven
2 opmerkingen
How dumb does not advise if it is right or left hand thread Bolt.
George Spiteri - Antwoord
Very informative but forgot the most important detail. Is this a left hand or right hand thread?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 10,619
