Ga door naar hoofdinhoud
Mercedes W123 Trunk Lock Vacuum Actuator Replacement
Wat je nodig hebt
  1. Mercedes W123 Trunk Lock Vacuum Actuator Replacement, Trunk Lock Vacuum Actuator: stap 1, afbeelding 1 van 1
    • As you would expect, the trunk lock actuator is located in the trunk adjacent to the lock itself.
    • It is hidden just behind this black plastic cover.
  2. Mercedes W123 Trunk Lock Vacuum Actuator Replacement: stap 2, afbeelding 1 van 1
    • Remove this black plastic cover by prying it up from the bottom until it pops out enough to remove fully.
  3. Mercedes W123 Trunk Lock Vacuum Actuator Replacement: stap 3, afbeelding 1 van 1
    • You can now see the trunk actuator. It connects to the lock mechanism by the metal rod with a spring.
    • To remove the actuator begin by removing the two hex head screws. They should be 8mm heads.
    • Then disconnect the two vacuum lines, making note of their orientation. One is for lock (red stripe), one is for unlock (green stripe).
    • Finally, pull the metal armature of the actuator off of the lock mechanism. It pulls off in the direction of the vacuum actuator body.
  4. Mercedes W123 Trunk Lock Vacuum Actuator Replacement: stap 4, afbeelding 1 van 2 Mercedes W123 Trunk Lock Vacuum Actuator Replacement: stap 4, afbeelding 2 van 2
    • Remove the actuator from your car. Inspect it for obvious leaks.
    • On this actuator you can see that the outer diaphragm, on the lock side, is very obviously torn and so the actuator should be replaced.
    • If there were no obvious tears or cracks in the outside of the actuator you will need to use your vacuum pump with gauge to test the lock and unlock sides of the actuator.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.040 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.533 handleidingen geschreven
Één opmerking
Step 1 should be: Getting into the trunk with faulty vacuum actuator. Is there a way to do this without destroying the left lens assembly?
joshuaahopkins - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 56
Altijd: 9,304
