Ga door naar hoofdinhoud
Mercedes W123 Fuel Injector Hard Line Replacement
Wat je nodig hebt
  1. Mercedes W123 Fuel Injector Hard Line Replacement, Fuel Injector Hard Line: stap 1, afbeelding 1 van 1
    • Begin by marking the hard lines. Each one goes in only one location, it will make it easier to re-install the lines or to install your new lines if you mark where each shaped line goes on the injection pump/injectors.
  2. Mercedes W123 Fuel Injector Hard Line Replacement: stap 2, afbeelding 1 van 2 Mercedes W123 Fuel Injector Hard Line Replacement: stap 2, afbeelding 2 van 2
    • Then begin removing the clamps that hold adjacent hard lines together.
    • You'll use a 8mm socket on top of the bolt that holds the clamps together, and a 8mm box end wrench on the bottom nut that the bolt goes in to.
    • Go slowly with this and be careful to not drop the nuts or clamp pieces as they can fall behind the injection pump. It's not impossible to get them out, but it can be difficult.
    • The second picture shows the hard lines with all of the clamps removed. Be sure to re-install all of the clamps on the lines; they help prevent the lines from vibrating excessively. The vibration is what tends to cause them to crack!
  3. Mercedes W123 Fuel Injector Hard Line Replacement: stap 3, afbeelding 1 van 2 Mercedes W123 Fuel Injector Hard Line Replacement: stap 3, afbeelding 2 van 2
    • Now, use a 17mm wrench loosen the rear-most nuts on the hard lines at the injection pump.
    • Then, use the same wrench to loosen the nut on the same hard line at its respective injector.
  4. Mercedes W123 Fuel Injector Hard Line Replacement: stap 4, afbeelding 1 van 1
    • You can then remove that hard line.
    • Proceed in the same manner for the other lines until all are removed.
  5. Mercedes W123 Fuel Injector Hard Line Replacement: stap 5, afbeelding 1 van 1
    • While your hard lines are off, cover the hard line fittings on the pump as well as at each injector to prevent contamination from entering. The injector nozzles have very small openings that can be easily clogged.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.040 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.532 handleidingen geschreven
2 opmerkingen
Excelente Guia Muchas gracias!!!
Pippenpy - Antwoord
do you need to bleed the lines after you put them back on?
john umbanhowar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 11,056
