Ga door naar hoofdinhoud
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
Wat je nodig hebt
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: stap 1, afbeelding 1 van 1
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 2, afbeelding 1 van 1
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 3, afbeelding 1 van 1
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 4, afbeelding 1 van 1
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 5, afbeelding 1 van 1
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 6, afbeelding 1 van 3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 6, afbeelding 2 van 3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 6, afbeelding 3 van 3
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: stap 7, afbeelding 1 van 1
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.040 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
2 opmerkingen
Very informative, descriptive and point on analysis.
George T Peeke - Antwoord
Und wie wird dies beim Kombi gemacht?
srossius - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 86
Altijd: 12,283
