Inleiding
If the alarm of a battery-operated quartz analog clock does not sound, only sounds intermittently, or activates at the wrong time, a misaligned alarm trigger mechanism may cause the failure. This guide shows how to realign the internal alarm trigger in a battery-operated quartz analog alarm clock with an electronic buzzer.
The alarm trigger mechanism uses an electrical circuit to power the buzzer by transferring motion with gears from the alarm hand to an internal switch. When the gears and/or alarm trigger mechanism shift out of alignment, the buzzer fails to receive an electrical signal, which prevents it from sounding.
Before beginning this guide, verify that a dead battery or dirty battery contacts do not cause the alarm failure. Replace the battery with a new one and clean the contacts if there is any corrosion or debris. Set the alarm and manually advance the hands to confirm that the alarm fails to sound.
Wat je nodig hebt
Lay the clock facedown and remove the battery.
Unscrew the back cover.
Temporarily reinsert the battery.
Rotate the minute hand forward and watch what happens when the current time meets the alarm time.
Misalignment of the alarm trigger is confirmed if:
The alarm wheel misses the trigger lever.
The lever fails to move far enough to trigger the alarm.
The lever slips off the wheel and fails to ride over the wheel.
Één andere persoon heeft deze handleiding voltooid.
