Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Open the CD cover so that the latch can be accessed.
Using a 3/16" flat head screwdriver, gently pry in the corner of the latch and the boombox housing.
You should see the latch pop out of the housing a little bit.
Then move to the opposite side of the latch and gently pry there.
Keep moving back and forth until the latch comes loose and can be removed with your fingers.
When the latch is removed, it should like the part in the picture.
2 opmerkingen
where can i buy the cd cover latch part
https://www.amazon.com/Latch-WFCO-Conver... This might work
