Ga door naar hoofdinhoud
Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement
Wat je nodig hebt
  1. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement, CD Cover Latch: stap 1, afbeelding 1 van 1
    • Open the CD cover so that the latch can be accessed.
  2. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: stap 2, afbeelding 1 van 1
    • Using a 3/16" flat head screwdriver, gently pry in the corner of the latch and the boombox housing.
    • You should see the latch pop out of the housing a little bit.
    • Then move to the opposite side of the latch and gently pry there.
    • Keep moving back and forth until the latch comes loose and can be removed with your fingers.
  3. Memorex 2Xtreme MP3830-01 CD Cover Latch Replacement: stap 3, afbeelding 1 van 1
    • When the latch is removed, it should like the part in the picture.
Conclusie
Meghan
579 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-4, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-4, Duarte Fall 2014
UMASSD-DUARTE-F14S2G4
4 Leden
6 handleidingen geschreven
2 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 2,219
