Ga door naar hoofdinhoud
Maytag MVWX655DW1 Washer Basket Hub Replacement
Wat je nodig hebt
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: stap 1, afbeelding 1 van 1
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 2, afbeelding 1 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 2, afbeelding 2 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 2, afbeelding 3 van 3
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 3, afbeelding 1 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 3, afbeelding 2 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 3, afbeelding 3 van 3
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 4, afbeelding 1 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 4, afbeelding 2 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 4, afbeelding 3 van 3
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 5, afbeelding 1 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 5, afbeelding 2 van 3 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 5, afbeelding 3 van 3
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 6, afbeelding 1 van 2 Maytag MVWX655DW1 Washer Basket Hub Replacement: stap 6, afbeelding 2 van 2
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
Conclusie
Kyle
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 239
Altijd: 8,663
