Ga door naar hoofdinhoud
Maytag Dishwasher Control Board Replacement
Wat je nodig hebt
  1. Maytag Dishwasher Control Board Replacement, Remove the Front Door Panel: stap 1, afbeelding 1 van 2 Maytag Dishwasher Control Board Replacement, Remove the Front Door Panel: stap 1, afbeelding 2 van 2
    • Before beginning, it is essential to cut all power to the dishwasher, as lethal voltages are present in the circuitry. If equipped with a plug, unplug the power cord; otherwise cut off the power at the circuit breaker.
    • Open the dishwasher door fully until it is laying flat parallel with the floor.
    • Remove the 12 T-15 Torx screws along either side of the door panel. Save the two nearest the hinges for last.
    • While supporting the front door panel with your hand, remove the two longer T-15 screws on either side of the door latch.
    • The front door panel will fall onto the floor if you do not support it when you remove the final screw.
    Vraag FixBot
    Voeg opmerking toe
  2. Maytag Dishwasher Control Board Replacement: stap 2, afbeelding 1 van 2 Maytag Dishwasher Control Board Replacement: stap 2, afbeelding 2 van 2
    • Raise the door back to an upright position, but do not close it fully until it latches.
    • Grasp the door by the handle in preparation for removing it.
    Vraag FixBot
    Voeg opmerking toe
  3. Maytag Dishwasher Control Board Replacement: stap 3, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement: stap 3, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement: stap 3, afbeelding 3 van 3
    • Pull the door panel forward a couple of inches.
    • There are two retaining brackets near the hinges on either side of the door panel. Lift the door straight up at least six inches until you clear those brackets.
    • The door panel is now free and can be set aside.
    Vraag FixBot
    Voeg opmerking toe
  4. Maytag Dishwasher Control Board Replacement, Remove the Control Panel: stap 4, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement, Remove the Control Panel: stap 4, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement, Remove the Control Panel: stap 4, afbeelding 3 van 3
    • Having something to rest the control panel on as you work will make the rest of this procedure much simpler. A dog food bin was the perfect height and size in my case.
    • Grasp the control panel and lift straight up to release it from the door.
    • Lay it down in preparation for removing the control board.
    Vraag FixBot
    Voeg opmerking toe
  5. Maytag Dishwasher Control Board Replacement, Remove the Control Board Cover: stap 5, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement, Remove the Control Board Cover: stap 5, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement, Remove the Control Board Cover: stap 5, afbeelding 3 van 3
    • The control board cover is held on by two latches, one on either side. The first one is shown on the opposite side near the bundle of wires.
    • The other latch can be seen directly below my thumb in the second photo; simply press in to release it.
    • The cover is now free and can be removed and set aside.
    Vraag FixBot
    Voeg opmerking toe
  6. Maytag Dishwasher Control Board Replacement, Unplug the Board Connectors: stap 6, afbeelding 1 van 2 Maytag Dishwasher Control Board Replacement, Unplug the Board Connectors: stap 6, afbeelding 2 van 2
    • Remove the two wires connected to the Thermal Fuse. Note that they can be difficult to unplug and you may have to hold the fuse down with one hand to avoid pulling it out of its bracket.
    • Unplug the two large power connectors by grasping the black plastic part of the connector and pulling straight up on both of them.
    Vraag FixBot
    Voeg opmerking toe
  7. Maytag Dishwasher Control Board Replacement, Disconnect the Touch Panel: stap 7, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement, Disconnect the Touch Panel: stap 7, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement, Disconnect the Touch Panel: stap 7, afbeelding 3 van 3
    • At this point the control board is held in by two latches, seen here being pointed to by red arrows. Releasing both of them will allow you to lift the board from the control panel.
    • Do not attempt to remove the control board completely as there are still several wires to be unplugged.
    • Unplug the touch panel by sliding the connector directly away from the control board.
    Vraag FixBot
    Voeg opmerking toe
  8. Maytag Dishwasher Control Board Replacement, Unplug the Edge Connectors: stap 8, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement, Unplug the Edge Connectors: stap 8, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement, Unplug the Edge Connectors: stap 8, afbeelding 3 van 3
    • Three edge connectors remain. Flip the board around and set it on edge to access them.
    • Each connector is held in with a single latch; bend the latch slightly then carefully grasp the wires and lift straight up to remove the connector.
    Vraag FixBot
    Voeg opmerking toe
  9. Maytag Dishwasher Control Board Replacement: stap 9, afbeelding 1 van 3 Maytag Dishwasher Control Board Replacement: stap 9, afbeelding 2 van 3 Maytag Dishwasher Control Board Replacement: stap 9, afbeelding 3 van 3
    • Remove the remaining two connectors.
    • The edge connectors are different sizes and the wires are color coded, so you have to work at it to get the connectors wrong, since each one is labelled according to color.
    Vraag FixBot
    Voeg opmerking toe
  10. Maytag Dishwasher Control Board Replacement: stap 10, afbeelding 1 van 1
    • The control board is now free.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
Jerry Wheeler
94.922 Reputatie
92 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 72
Altijd: 1,577
