Inleiding
Keyboards can be damaged when liquids are spilled on them. Without a functioning keyboard, it can be very difficult to use the Maylong MN-1000P. Replacing a keyboard is not difficult and requires only a few simple tools.
Wat je nodig hebt
Place the netbook top down, with the opening of the netbook facing you.
Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
Hold the keyboard panel with the back facing you.
Using your thumbs, push on the silver squares.
