Ga door naar hoofdinhoud
Maylong M-270 Battery Replacement
Wat je nodig hebt
  1. Maylong M-270 Battery Replacement, Motherboard: stap 1, afbeelding 1 van 2 Maylong M-270 Battery Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Battery Replacement: stap 2, afbeelding 1 van 2 Maylong M-270 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Battery Replacement: stap 3, afbeelding 1 van 2 Maylong M-270 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
  5. Maylong M-270 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Maylong M-270 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
  6. Maylong M-270 Battery Replacement: stap 6, afbeelding 1 van 3 Maylong M-270 Battery Replacement: stap 6, afbeelding 2 van 3 Maylong M-270 Battery Replacement: stap 6, afbeelding 3 van 3
    • Remove the battery by using the spudger to gently pry the battery away from metal case around the front screen.
Conclusie
Adam Sanders
222 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 706
