Ga door naar hoofdinhoud
Mayflash Arcade Stick F300 Microswitch Replacement
Wat je nodig hebt
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: stap 1, afbeelding 1 van 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: stap 1, afbeelding 2 van 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: stap 1, afbeelding 3 van 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: stap 2, afbeelding 1 van 2 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: stap 2, afbeelding 2 van 2
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 Microswitch Replacement: stap 3, afbeelding 1 van 3 Mayflash Arcade Stick F300 Microswitch Replacement: stap 3, afbeelding 2 van 3 Mayflash Arcade Stick F300 Microswitch Replacement: stap 3, afbeelding 3 van 3
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
  4. Mayflash Arcade Stick F300 Microswitch Replacement: stap 4, afbeelding 1 van 2 Mayflash Arcade Stick F300 Microswitch Replacement: stap 4, afbeelding 2 van 2
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Saul Aguiar
293 Reputatie
2 handleidingen geschreven
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Lid van Utah Tech University, Team 1-4, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G4
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 63
Altijd: 421
