Ga door naar hoofdinhoud
Mayfan Joy-con for Switch - Repair of shoulder button
Wat je nodig hebt
  1. Mayfan Joy-con for Switch - Repair of shoulder button, Mayfan Joy-con for Switch - Repair of shoulder button: stap 1, afbeelding 1 van 2 Mayfan Joy-con for Switch - Repair of shoulder button, Mayfan Joy-con for Switch - Repair of shoulder button: stap 1, afbeelding 2 van 2
    • Use a J0 Philips screwdriver to carefully remove the four screws. Screw head strips easily. Do not force it.
  2. Mayfan Joy-con for Switch - Repair of shoulder button: stap 2, afbeelding 1 van 1
    • Use a pry tool to open the controller once the screws are removed. The plastic cover for the shoulder button will most likely fall out. There are no springs on this button.
  3. Mayfan Joy-con for Switch - Repair of shoulder button: stap 3, afbeelding 1 van 1
    • The button will be bent back. This is especially visible from the front. You will see a gap between PCB and the button. Use some needle-nose pliers to bend the button back such that it is flush with the PCB.
Conclusie
To reassemble your device insert the shoulder button cover, and follow these instructions in reverse order.
Note: With additional drops the button will bend again and eventually break. The way it is mounted is a bad mechanical design.
D3vMarc
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 26
Altijd: 982
