Ga door naar hoofdinhoud
Mavic 2 Main Board Replacement
Wat je nodig hebt
  1. Mavic 2 Main Board  Replacement, Remove screws: stap 1, afbeelding 1 van 1
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: stap 2, afbeelding 1 van 3 Mavic 2 Main Board  Replacement, Continue to remove screws: stap 2, afbeelding 2 van 3 Mavic 2 Main Board  Replacement, Continue to remove screws: stap 2, afbeelding 3 van 3
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: stap 3, afbeelding 1 van 2 Mavic 2 Main Board  Replacement: stap 3, afbeelding 2 van 2
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: stap 5, afbeelding 1 van 1
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Robert Contraction
229 Reputatie
1 Handleiding geschreven
1Gids Commentaar
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 61
Altijd: 1,867
